Best Bolt Ons 5.0 ???
I have a 1989 GT with 78,000 miles I have a Flo Master exhust cat back system, 9mm wires, K&N air filter, 373 gears and a set of underdrive pullies, Can anybody tell me about any other bolt-ons I can do , i was thinking about a 65mm TB, But I don't know what else is involed.
RE: Best Bolt Ons 5.0 ???
lol supercharger is a bolt on but not a cheap one. Try a upper/lower plenum 1.7 roller rockers pedastel mount go 1.7 if you dont want to mess with the cam. The stock 5.0 cam is pretty good.Headers. Your best bet is to get air IN and OUT as efficently as possible. If i was you id go headers a non cated x-pipe if you can 1.7 RR 65mm tb and spacer upper and lower intake and some bfgoodwrench drag radials and you should have a good car. Also get some subframe connectors and do that torque box mod.
ORIGINAL: silentvoice19
lol supercharger is a bolt on but now a cheap one. Try a upper/lower plenum 1.7 roller rockers pedastel mount go 1.7 if you dont want to mess with the cam. The stock 5.0 cam is pretty good.Headers. Your best bet is to get air IN and OUT as efficently as possible. If i was you id go headers a non cated x-pipe if you can 1.7 RR 65mm tb and spacer upper and lower intake and some bfgoodwrench drag radials and you should have a good car. Also get some subframe connectors and do that torque box mod.
