Top End Kit Question
Old 12-02-2007, 11:13 PM
White92FoxGT
White92FoxGT's Avatar
Default RE: Top End Kit Question
Care to suggest something then?
White92FoxGT is offline
Old 12-02-2007, 11:23 PM
crazyhorse
crazyhorse's Avatar
summitracing.com
ORIGINAL: White92FoxGT
Also where can i get the trick flow kit for a pretty low price?
crazyhorse is offline
Old 12-02-2007, 11:26 PM
86 5.0L
86 5.0L's Avatar
can you piece together your own kit?
86 5.0L is offline
Old 12-03-2007, 12:44 AM
White92FoxGT
i could
Old 12-03-2007, 12:46 AM
86 5.0L
86 5.0L's Avatar
i could
i mean do you know whats involved in a H/C/I swap?
if not go with the TF kit, comes with everything to finsh the swap
86 5.0L is offline
Old 12-03-2007, 01:04 AM
92GreyGT
92GreyGT's Avatar
I don't know, that kit from 50resto isn't that bad and everything is in there. As far as which kit will make more power, I don't either one is leaps and bounds better than the other.It will come down to personal preference, if you want to stick with all Ford then go 50 resto. If it were me I would go with the Trick Flow, their heads are very versital and their are some places that will CNC port them to be just about as bad as you want to be.
If you are going to piece one together I would go AFR, with a Trick Flowor Edelbrock intake. Edelbrock makes good intakes but I am not crazy about their heads.
92GreyGT is offline
White92FoxGT
Well i could learn, i've been doing research but if you have an opinion on what to get, inform me.
Old 12-03-2007, 01:06 AM
92GreyGT
92GreyGT's Avatar
What's your budget and how much power do you want to make?
92GreyGT is offline
Old 12-03-2007, 01:08 AM
White92FoxGT
What cam would you choose 92GreyGT? Ive been researching the AFR's and i think i may get the 165's. What about the typhoon intake?
Old 12-03-2007, 01:10 AM
White92FoxGT
Well im usin my moms credit card so probably no more than $2600 since i do have to pay it back. My goal would be close to 300hp
Quick Reply: Top End Kit Question
