Turbo/SC help
Turbo/SC help
Iv been looking at a few different kinds of forced indution and was wundering what you guys thought about the dfferent brands. im looking for either a turbo or SC for under 3200 and thought you might know what is the best bang for my buck. the only one i cant use is the proharger because of the placement under the hood, i cant relocate the batterie because of soundsystem in the trunk. so any segestions on what would work good would be great.
Thanks
RE: Turbo/SC help
Even if you did not have a soudsystem in the trunk you would not want a Procharger. IMO. Look at Vortech S Trim, KB, and there's a bunch of turbo systems that would work. Are you going to do the install? A mechanics labor may put you over your budget plus you will need a good tune so factor that in as well.
RE: Turbo/SC help
ORIGINAL: 92Rideagain
Please explain
RE: Turbo/SC help
im not sayin that a procharger wouldnt be sweet..but u might need to custom some of it..like for the sn 50s...the air filter is placed right above the driver side header...sucking what might be the hottest air in the engine compartment lol...theres ways around it...if samseed was still around he had a procharger on his sn 50 and he found a way around it
