70mm MAF $5.00
70mm MAF $5.00
It is official,
you can take the MAF housing off a
1992-1994 4.6
Crown Victoria
Grand Marquis
Town Car, cut off the ears with a grinder and smooth the ledge some, before
installing your original sensor onto the housing without having any problems. Paid $5.00 and
got hell of performance and throttle response ! !
NEW 70MM BODY $ 5.00
OLD 55MM BODY JUNK!
RE: 70mm MAF Technical Conversion
there will be 4 ears with holes for 4 bolts to hold the housing, to the 4.6's airbox. Your original
housing, does not have this design.
Therefore the ears must be removed, to obtain a circular shape of the front of the housing.
ORIGINAL: 50Stocker
what ears are you talking about? I have not looked at one that closely...What other mods are you running?
good to know...I didn't look at the part about it being a 4.6. Thanks for another project! My motor is stock for now, but I am opening up the breathing right now(stubbies and O/R H going, two chamber flows already), so this seems like a good mod to do...
ORIGINAL: 50Stocker
This would go great with removing throttle cable slack.
