coolant out of the valve cover
Old 12-22-2007, 08:38 AM
five0fm
five0fm's Avatar
Default coolant out of the valve cover
anyone know what causes this. like which gasket or are the heads warped. anyone have this problem before
five0fm is offline
Old 12-22-2007, 08:41 AM
my77stang
my77stang's Avatar
Default RE: coolant out of the valve cover
elaborate? if your talking a couple drops under the oil fill cap that can be condensation and is perfectly OK. if you really have a leak somewhere check your dipstick and see if its milky colored
my77stang is offline
Old 12-22-2007, 09:02 AM
five0fm
five0fm's Avatar
thatsy im confused. the car seems to be running great. the oil is normal color. when i rev it up past about 5k there is a little stream that leaks between the valve cover and the head.
five0fm is offline
Old 12-22-2007, 09:23 AM
my77stang
my77stang's Avatar
wtf[&:]
maybe intake gasket leaking where the coolant passages are at the front and rear or the heads..... building up pressure causing the gasket to leak a little.
Old 12-22-2007, 12:29 PM
five0fm
five0fm's Avatar
so how should i go about fixin it..just change the head to lower intake gaskets and oil and be done with it?
five0fm is offline
Old 12-22-2007, 12:33 PM
shawnk007
shawnk007's Avatar
Are you sure its not oil?
shawnk007 is offline
Old 12-22-2007, 12:36 PM
HACKGT350
HACKGT350's Avatar
ripped it down and rebuild it haha. nah pressure test your cooling system with the valve cover off and see where that leak is coming from
HACKGT350 is offline
Old 12-22-2007, 12:38 PM
five0fm
five0fm's Avatar
how can i do that without getting oil all over the place..n it only happens when i rev it really high like over 5000....and yes im sure its coolant..its green lol
five0fm is offline
Old 12-22-2007, 12:46 PM
HACKGT350
HACKGT350's Avatar
when you pressurize the system the car is off. they sell kits that hook up to the radiator and pressurize the system with air from a compressor. if you have a leak it will force it out where ever the leak is
Old 12-22-2007, 12:50 PM
Cobra77
Cobra77's Avatar
Also so you can rent this tool from AutoZone, if you have one around.
Cobra77 is offline
Quick Reply: coolant out of the valve cover
