She started running rich :(
Old 03-17-2005, 07:11 PM
bobby
bobby's Avatar
Default RE: She started running rich :(
ORIGINAL: Dbeck002
checked each plug, they are gapped fine. doesnt seem to be the plugs, thanks anyway though bobby [&:]
plugs look a little whitish though.
LEAN
bobby is offline
Old 03-17-2005, 07:42 PM
Dbeck002
I ♥ Acer
Dbeck002's Avatar
how can it be lean if im getting 10 MPG?
Dbeck002 is offline
Old 03-17-2005, 07:46 PM
Skitter
Skitter's Avatar
oil change? [&:]
Skitter is offline
Old 03-17-2005, 07:50 PM
Dbeck002
I ♥ Acer
Dbeck002's Avatar
changed oil 1500 miles ago and it looks really good. dunno how that would affect gas mileage though.
did i mention that the engine temp on the way to school and on the way home was a tad high, not high but HIGHER than normal. it was still below 160, but im used to seeing it at 140. so i dunno what is causing that, maybe the problem is working on conjunction with engine temp and gas mileage. im thinking the rich condition is causing the engine temp to be weird. it might be my O2s, dammit i dont wanna buy new ones.
Dbeck002 is offline
Old 03-17-2005, 08:56 PM
luckythirteen13
luckythirteen13's Avatar
dude! your car is running way to cold. how many times do i have to tell you dont leave that fan on all the time. in a 30 minuted drive my fan might be on for 5 minutes.
let the temp come up to 180
luckythirteen13 is offline
Old 03-17-2005, 09:11 PM
88PatrolCar
88PatrolCar's Avatar
You want your plugs to have a little white to them.
88PatrolCar is offline
Old 03-17-2005, 09:12 PM
BigMg
BigMg's Avatar
I agree way to cold but that is not the main problem cuz u always see your temp at 140 so did you check the fual press while running and did you check the vacume line going to it? And that code you pulled is i think a maf code
BigMG
BigMg is offline
Old 03-17-2005, 09:17 PM
vfast
I ♥ Acer
vfast's Avatar
also clean you maf electronics as it may have some oil residue on it from your filter..
vfast is offline
Old 03-17-2005, 11:35 PM
roundman
roundman's Avatar
ORIGINAL: Dbeck002
i got code 54, 31, 85
31 and 85 have been there for months, just EGR bull****.
code 54 is the new code its weird, the book says
"Vane air flow sensor or air charge temperature sensor"
straight from the haynes manual, i didnt know we had air charge temp sensors in the 5.0s. whats this mean?
it's either the MAF sensor OR the air temperature sensor built into the same housing with the MAF (vane air sensor). that what the code 54 is telling you to check out. probably got oil from the air filter on the wires in the MAF and this is making it act up on you.
roundman is offline
Old 03-17-2005, 11:42 PM
bobby
bobby's Avatar
ORIGINAL: roundman
ORIGINAL: Dbeck002
i conquer
bobby is offline
Quick Reply: She started running rich :(
