long tube header question
Old 01-06-2008, 06:54 PM
Stroked91
Stroked91's Avatar
Default long tube header question
i am lookin into buying some long tubes. is there any really difference between summit, flow tech, or bbk. and will i have any steering shaft problems with these headers. its on a 88 gt
Stroked91 is offline
Old 01-06-2008, 07:08 PM
92GreyGT
92GreyGT's Avatar
Default RE: long tube header question
I had Flow Techs at one time and they are good for the money. You need to buy Flow Tech's H-pipe with them, they use a gasket, 3 bolttype connection at the header instead of the ball and socket factory style connection.If you can afford it get the BBKs, they are well made and fit really well. I had no problems put them on and if anything I have more ground clearance now than I did before.
92GreyGT is offline
Old 01-06-2008, 07:20 PM
my77stang
my77stang's Avatar
hookers > hedman tork-step > everything else
probably?!?!
my77stang is offline
Old 01-06-2008, 07:40 PM
holyshift
holyshift's Avatar
I just bought the Jegs long tubes, havent installed them yet, but they look like there pretty quality. I plan on just running either open header, or running extensions with dynomax bullets, dunno yet. Dont do to much street driving so thats not a concern.
holyshift is offline
Old 01-06-2008, 07:42 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I have flowtech long tubes and matching x-pipe..and for the money they are decent but you have to cut the flange on the passanger side and piece back together 3 of the tubes for install and once on the driver side..what sucked was all the piece together connections leaked and I had to wrap them with header wrap..other than that they are decent
mjr46 is offline
Old 01-06-2008, 07:59 PM
Stroked91
Stroked91's Avatar
damn not really up for piecing together a set of headers. i may as well just buy some bbk long tubes
Old 01-06-2008, 10:02 PM
Tberg725
Tberg725's Avatar
i recommend the BBK LT's, i installed a set on my car and they fit great and are awsome quality
Tberg725 is offline
Old 01-06-2008, 10:45 PM
Stella94GT
Stella94GT's Avatar
im ordering a set of ceramic bbk long tubes this week. i picked them becuase they seem to have the smoothest designe out of the rest.
Stella94GT is offline
Old 01-07-2008, 05:00 PM
5spd GT
5spd GT's Avatar
Out of those, your best fit and likely quality is going to be the BBK line.
5spd GT is offline
Old 01-07-2008, 05:07 PM
terdstang
terdstang's Avatar
not to steal the spot light but does anyone know of a LT that works with AOD other then Bassani??
terdstang is offline
Quick Reply: long tube header question
