Help me find a 12v Key on source.
I am installing my Snow Methanol kit and need to connect the module to a +12v key on source that has a 25 AMP fuse. I am not very good with electrical so I have no clue where I could find this source. Anyone have any suggestions for me? Thanks!
RE: Help me find a 12v Key on source.
grab a test light and open the fuse box up and turn the key on and touch the test light to the top of the fuse where metal shows and switch key on and off testing each fuse until you find one that is switch 12 v with proper amperage
I have an 87 GT...fuse box is located to the left of the steering column. I have some aftermarket gauges that light up. I ran the 12v bulb wire to the 20amp fuse for the radio. Turn the key on, lights come on. It's not too hard. You can probably do the same thing. Find a 25amp fuse in the fuse box and strip the wire down, pull the fuse, put the wire in the hole and push the fuse in. The metal prongs on the fuse should push the wire into the clasps and the wire will be secured. Voila.
ORIGINAL: 87gt5o
09-08-2015 11:50 AM
