injector size
Old 01-11-2008, 01:21 AM
five0fm
five0fm's Avatar
Default injector size
i have a paxton sn-89 supercharger with a smaller pulley,upr boostmaster pipe and a custom boost cooler. i think its safe to say im making under 10lbs i also deleted all my smog stuff if that makes a difference with bbk equals and flowmasters. im wondering what size injectors i should run. i have a set of 42lbs injectors layin around but i think they are too big. any thoughts on this?
five0fm is offline
Old 01-11-2008, 02:42 AM
greenstreak9205
greenstreak9205's Avatar
Default RE: injector size
any other mods? such as heads or cam...
greenstreak9205 is offline
Old 01-11-2008, 07:48 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if your engine is fairly stock and you are running 6-8 lbs?? then 30 lbs injectors should be okay but you really need to get a gauge on the car and measure how much boost you are producing to get an accurate idea of what you should have
mjr46 is offline
Old 01-11-2008, 09:28 AM
5spd GT
5spd GT's Avatar
They are not too big if you get a tune.
5spd GT is offline
Old 01-11-2008, 10:09 AM
bouchermb
bouchermb's Avatar
I havea set of 30 lb. FRPP inj. that have about 200 miles on them, if you're looking for 30's.
bouchermb is offline
Old 01-11-2008, 11:12 AM
91camaroeater
91camaroeater's Avatar
if you do a custom chip and tune, the 42's will work reguardless of what you have done to the car. then you just have the car retune when you do more things
91camaroeater is offline
mltdwn12
09-23-2015 08:54 AM
Demodulates
09-18-2015 11:14 AM
pimp2303
09-17-2015 08:45 PM
uedlose
09-10-2015 01:37 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: injector size
