Starting Problem
Starting Problem
When I turn ignition1st time nothing happens, not a sound...then it fires right up on 2nd turn of the ignition. After it fired up on 2nd try, I turned it off and it fired up on 1st try.
RE: Starting Problem
ORIGINAL: camaroeater
Also if an automatic, could be your neutral safety switch or if stick could be your clutch switch.
Get it to not crank and you can check it out.
Any updates on this?
I'm kinda having the same issue, just now it won't start at all. I've checked the starter relay... I was going to check the clutch switch today, but it's snowing too bad to work on the car outside.
sounds like your car doesnt like to much advance. mine used to do the same thing back it down 1 or 2 degrees it should help it. 15 is pushing it just a bit you might have some top end pinging. mine is set at 14* no problems fires up right away everytime even when its 5* out in the morning
KEM Motorworks
08-14-2015 10:13 PM
