PUSHRODS
Old 01-15-2008, 07:34 PM
whitestang86
whitestang86's Avatar
Default PUSHRODS
I'm tryin to figure our what stock size and lenght pushrods are in the 86-5.0 so i can go out and get some new chromemoly ones
whitestang86 is offline
Old 01-15-2008, 07:53 PM
thesource
thesource's Avatar
Default RE: PUSHRODS
6.250
thesource is offline
Old 01-15-2008, 08:05 PM
whitestang86
will it change length if you go to a a full roller rocker?? cause i'm thinkin of gettin the trickflow rockers but keeping the hydralic roller cam and lifters.
Old 01-15-2008, 09:22 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it shouldn't change to much..but either way if you get pedastal mount rockers you still need to check for proper contact spot of the roller tip on the valvestem and that is determined by push rod length so you need a checker to properly gauge everything
mjr46 is offline
Old 01-15-2008, 09:40 PM
whitestang86
i know the heads i'm probably getting have the stud in the heads already so i was just goin with the stud mounted rockers but if the stock is 6.25 on the pushrod, would 6.375 be allowable? its not that much longer, i wouldn't think it wouldn't be that much of a tollerance problem but then again this is precision parts working together.
69Volunteer
09-30-2015 10:39 AM
S'PortMustang69
08-30-2015 08:27 PM
hawaii5.0
04-13-2005 05:25 PM
Dan89lx
02-16-2005 09:04 PM
Quick Reply: PUSHRODS
