CAM IT!
Old 01-27-2008, 03:13 AM
Notch90
Notch90's Avatar
Default CAM IT!
whats the best cams to go with a stock block afr 165 heads systemax II intake?
IDEAS? BAD CAMS? VIDEO CLIPS WITH SOUND!!!
i want to be able to turn the radio off and just listenin to the motor hummmmmmm
lol
Notch90 is offline
Old 01-27-2008, 07:47 AM
Joel5.0
Joel5.0's Avatar
Default RE: CAM IT!
The best cam would be one tailored to the specific combination you have installed to provide you with the performance goals you are expecting...... which are??? .... or is it just a sound thing? .... if it's performance and/or driveability you're looking for.... you may want to check this custom alternative.....
Joel5.0 is offline
Old 01-27-2008, 10:00 AM
5spd GT
5spd GT's Avatar
Default RE: CAM IT!
Ed Curtis @ www.flowtechinduction.com.
The sound of a camshaft can change from car to car, because of so many variables. The top-end pieces used, compression, idle speed, exhaust, etc.
Ed sells the AFR heads and has them in stock, like the ones you have. He will get you the proper spec'd springs to go with the custom camshaft.
I had great luck with him. He can get you a camshaft designed for mild or all the way up to wild.
Read all of these...
5spd GT is offline
Old 01-27-2008, 12:05 PM
bouchermb
bouchermb's Avatar
Default RE: CAM IT!
Alot of others, including myself, got a custom grind from Jay Allen at Camshaft Innovations.
bouchermb is offline
Old 01-27-2008, 01:42 PM
91hatchgt
91hatchgt's Avatar
Default RE: CAM IT!
ORIGINAL: bouchermb
Jay did my cam for my 331, he is a great guy to work with, and fast as well.
91hatchgt is offline
Old 01-27-2008, 02:17 PM
1995mustang818
1995mustang818's Avatar
Default RE: CAM IT!
why go with
165s most people only about 290 to 300 rwhp why not step it up with some 185s maybe have a better result and as for a cam like some people here suggested go with a custom cam that is designed for your car
1995mustang818 is offline
Old 01-27-2008, 02:20 PM
w8less
w8less's Avatar
Default RE: CAM IT!
i agree get a set of 185s, a custom cam and the proper springs suggested from the cam grinder
w8less is offline
Old 01-27-2008, 02:54 PM
5spd GT
5spd GT's Avatar
Default RE: CAM IT!
AFR 185 heads are great, but the intake valve is larger. This typically creates a piston to valve clearance issue with stock pistons.
A custom camshaft grinder can get them to clear.
I prefer, to put AFR 185cc heads on a bit higher compression 302-306, other than stock compression.
I like the AFR 165cc (1.90" valve) for stock compression 302-306 cars. It gives the custom cam grinder more room to play with in designing the camshaft, instead of having to factor in the larger 185cc valve.
5spd GT is offline
Old 01-28-2008, 12:23 AM
Notch90
Notch90's Avatar
Default RE: CAM IT!
Yeah im tryin to go with a stock block to save money rite now. so i was thinkin the afr 165 58cc ..holley systemax II intake.
i hear that theres a new version Pro Port CNC's, its supposed to be 170 cc heads? any one heard of it?
Notch90 is offline
Old 01-28-2008, 12:29 AM
w8less
w8less's Avatar
Default RE: CAM IT!
you would only have to have the pistons flycut for the larger 2.02 valve nothing about a different block
w8less is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: CAM IT!
