Head problems see pictures !
Old 02-03-2008, 01:38 PM
dukeme
dukeme's Avatar
Default Head problems see pictures !
Here,s the deal...I am almost sure but you never know? After starting and letting the car warm up it starting hissing and dripping anti freeze from the last header bolt or in that area. I took some pictures to try to shed some light? Guesses?
This is closest to driver, I cleaned around the head
The below picture is only after a few minutes of shutting it off. You can see the puddle
[align=left] [/align]
dukeme is offline
Old 02-03-2008, 03:34 PM
charlesm489
charlesm489's Avatar
Default RE: Head problems!
i dont see any coolant around the header bolts or flange...check all your freeze plugs including the ones in the front of the cylinder heads (stock)
charlesm489 is offline
Old 02-03-2008, 04:15 PM
AdderMk2
Banned
AdderMk2's Avatar
didnt we go over this already... a LONG time ago!!!
the coolant is coming up past your rear most head stud. drain out your coolant, unbolt the stud, pull it out, clean it off.. add ALOT of thread sealant, screw it back in, and torque it down
AdderMk2 is offline
Old 02-03-2008, 04:21 PM
dukeme
dukeme's Avatar
You are right, we did...But the car has been stored and just today I started it up and after it warmed up...Well, now you see it. I will do what you said..Thanks Big Guy!
dukeme is offline
Old 02-03-2008, 04:57 PM
nitrous_bob
nitrous_bob's Avatar
man just when i thought nothing looked better than a notch doing a burnout...hereis a topless 'vert w/ a cowl hood smoking 'em up
i think i like it !
nitrous_bob is offline
Old 02-03-2008, 05:19 PM
dukeme
dukeme's Avatar
[align=left]
ORIGINAL: nitrous_bob
[/align]
i think i like it !
Sure enough, I drained the anti freeze, un did the stud bolt and took it out and low and be hold, a stream of anti freeze poured out...What is the proper procedure of sealing it up? Do I coat the threaded inbound side with sealant?
dukeme is offline
Old 02-03-2008, 05:27 PM
dukeme
dukeme's Avatar
Here is the exact location:
dukeme is offline
Old 02-03-2008, 06:42 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
^^^^^^^you need to remove the stud and coat the base stud threads with high temp teflon thread sealant and reinstall and torque to proper range....the lower studs all enter water jackets so if you didn't use sealant on them..I'd remove them and do it
mjr46 is offline
Old 02-03-2008, 07:10 PM
dukeme
dukeme's Avatar
[align=left]
ORIGINAL: mjr46
[/align]
Job completed, I will let set up for a day fill back up and she if that was the problem? Hope so...Easy fix if so....
dukeme is offline
Old 02-03-2008, 07:13 PM
92cobra
92cobra's Avatar
dukeme, where in illinois are you located?
92cobra is offline
Quick Reply: Head problems see pictures !
