good stroker kit???
#21
RE: good stroker kit???
well man i found a friend that does alot of ford work and he said hes got a set of damaged brodix heads that need some work. one of the heads needs 2 guides and cleaned up and the other needs alittle welding which i am extremely good at aluminum welding and a couple gudes and 1 new seat. 100 bucks good deal?????their the TF 1 std. I was looking on their website and they say no less that 11.5 min compression??? now can i puch it lol and go lower how will this effect my performance?
http://www.brodix.com/heads/track1ford.html
#26
I honestly didn'tthink about them until I read another thread was RHS heads. If you get Muscle Mustangs andFast Fords magazine they put them on a 331with a Trick Flow intake and cam and it made good power. Trick Flow heads are priced right and would make good power. RHS andAFR are also good heads.
#29
You need to look in the 200cc range.
Volume does not mean everything, because the runner length could be different.
Run a dished piston, low combustion chamber.
I would run AFR 205cc heads on a 347, but they are pushing 2k
