issues still
Old 02-07-2008, 02:14 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default issues still
ok this car must have gremlins or something, i took it out the other day before the big snow hit.
i have reset everything, timing, base idle, tps volt, everything within spec.
the rear six plugs are fouling(with fuel)and the front two look fine.(front of the motor) the car has no idle problems it just has an interemittin power kick at about 3500 rpms to redline.
the only symptom i have of it not being 100% is the fouling plugs and when i start the car. first start it runs fine for about 5 seconds and then sputters and dies. i'll start it again and it runs without an issue.
also the car just sounds...quiet? doesnt sound like it use to, not as much punch to its idle, just sounds quiet and the only that that has been changed is cleaned heads and typhoon intake.
FivePointOhh is offline
Old 02-07-2008, 05:25 PM
silentvoice19
silentvoice19's Avatar
Default RE: issues still
timing off?
silentvoice19 is offline
Old 02-08-2008, 10:07 AM
FivePointOhh
in limbo
lol, nah. double triple quadrupal checked. balancer is not spun, 100% sure of that.
my thoughts may have been FPR but i dont know how to verify if the diaphram is ruptured
Old 02-08-2008, 12:27 PM
FivePointOhh
in limbo
bump
Old 02-08-2008, 03:51 PM
FivePointOhh
in limbo
ttt
Old 02-08-2008, 09:20 PM
FivePointOhh
in limbo
bow chica wow wow...
Old 02-08-2008, 09:26 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: FivePointOhh
two thing you can do are hook in a fuel pressure gauge and test drive it......and while it's running pull vaccum line to fpr and see if it's wet with fuel
mjr46 is offline
Old 02-10-2008, 12:00 PM
FivePointOhh
in limbo
ORIGINAL: mjr46
thanks mjr, but does my issue sound like the fpr? that just a guess on my behalf.
i will try that in a little bit but i dont have a pressue gauge so i'll pull the vac line while its running and check.
Old 02-10-2008, 08:20 PM
FivePointOhh
in limbo
bump
Old 02-11-2008, 06:00 PM
silentvoice19
got good spark??? i know you said the fronts are fine but dude its a car lol anything can happen.
Quick Reply: issues still
