quick smog ?
Old 02-14-2008, 12:05 PM
Old_Smokey
Old_Smokey's Avatar
Default quick smog ?
So I just got my headers and catback in the mail and as my car is just about 100% original im just taking a precaution here. I am using a O/R H that my cousin gave me and the smog hose pipe on it was crimped closed (for obvious reasons) now since my smog system still operates fine and i have no intention of disconnecting it for the time being am I going to run into an issue when it comes to running the car? since I basically have to plug that smog line closed, will it throw a code? I am still going to hook up theO2's and everything but that seems to be the only thing thats gonna be disconnected. My car is running too mint, and Id rather not rig **** up. Thanks.
Old_Smokey is offline
Old 02-14-2008, 12:08 PM
bikeboy587
bikeboy587's Avatar
Default RE: quick smog ?
I'm pretty sure you will have to un-crimp that smog hose pipe so you can plug in the smog pipe from you car when you put it on....not 100% sure tho
bikeboy587 is offline
Old 02-14-2008, 12:10 PM
Ninety5five0
Ninety5five0's Avatar
I would also just uncrimp it and run it like it should be.
Ninety5five0 is offline
Old 02-14-2008, 12:13 PM
Old_Smokey
Old_Smokey's Avatar
I will have to look at the pipe again it seemed too bent to salvage...
Old 02-14-2008, 12:49 PM
Alero99
Alero99's Avatar
If its a long pipe with the end crimped... just cut it 1/4 inch down from the crimp... solved
Alero99 is offline
svfetter
10-05-2015 11:39 AM
Florida Regional Chapter
09-30-2015 08:04 PM
Teddi
09-29-2015 12:24 PM
09-25-2015 06:30 PM
Quick Reply: quick smog ?
