duraspark 2 with a roller cam
today i went to autoparts store they told me they would order a 1975 duraspark 2 with steel gear will work on my carb 302 rollor cam
is this the same dis. they used on the 85 ho gt mustang or do i need to tell them i need a 85 dis. for roller cam the duraspark 2 with steel cam should work right $50.00 price range
p.s. what does dizzy mean i been hearing people talk about a dizzy dis. whats a dizzy
RE: duraspark 2 with a roller cam
how do you get dizzy??? you turn round and round!!! what does a distributor do?? it turns round and round!!!...anyway....and there is no such thing as a 75 dizzy with duraspark II ordered with a steel gear.....that option wasn't until the first 302 production roller block in 85........so order a 85 distributor for a 5 speed car with the steel gear...only the 5 speed cars were 4 v h.o= roller cam equipped motors which had duraspark II
ORIGINAL: warggod
what was in the 85 mustang thats what i want to no was it the duraspark 2
He may be converting from FI to carb, and from the TFI dizzy, to the Duraspark II???. I'm going to do the same thing on my 89. I converted from a points dizzy to a Duraspark on my 74 F250 (using a GM style ignition module from Accel), and it has performedflawlessly for the last 2 years. $70 bucks for a rebuilt Duraspark, and $40 bucks for the module, add a 50,000 volt performance coil, and you've got a good street/strip ignition good to 7000rpm for less than the MSD distributor alone. Not for an all out race car, but a great low budget ignition system for a carb conversion. Personally I stay away fromthe Ford style Duraspark ignition boxes, as the aftermarket ones are problematic (thefactory Ford box is pretty good, but good luck finding one of them).
thanks just hope the motor i bought has the e7 heads on them i guess i need e7,s for the springs i bought for the e303 cam motor came out of a 89 mercury mer. it was a rollor cam also
i hopeeeeeeeeeeeeeeeeeeeee
Are the heads stock?, if the answer is yes, you probably won't be happy with that cam/head combo. The better choice would be a set of GT40s first, cam second. In fact, the GT40s with 1.7 rockers and the stock cam will perform better than the stock e7s with an ecam. Just another opinion.
junior04
09-28-2015 10:53 AM
