9 inch axle housing ends
Old 02-20-2008, 10:41 PM
blands89gt
blands89gt's Avatar
Default 9 inch axle housing ends
Im taking my rear end out to have the axle tubes welded and i want to have 9in ends welded on too but i dont know what ones to get. My rear end has 31 spline moser c-clip axles and an eaton LSD already. If i go to 9 in ends do i have to run c-clip eliminators? Also what axle bearing and seal do i need? any help would be very much appreciated. if possible include the part numbers too. Thanks
blands89gt is offline
Old 02-21-2008, 07:33 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: 9 inch axle housing ends
Running the 9" ends alleviates the need for the c-clip elims. The place you buy the 9" ends from should be able to tell you what seals and bearings you will need.
PRO50SC is offline
Old 02-21-2008, 07:51 AM
5.0kid
5.0kid's Avatar
call dts drivetrainspecialites they are doing the 9in ends on my 8.8 right now basicly they use a big bearing 9in end and a retaining plate thisenables you tousenon c clip axles plus it leaves room for disk brakes in the rear. give dts a call they will tell you every thing you need to know
5.0kid is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
mungodrums
10-07-2015 04:01 AM
09-10-2015 08:39 PM
Dragonus18
09-09-2015 01:21 AM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: 9 inch axle housing ends
