Confused
Confused
So Im really confused about this.... I have a 1990 GT5speed, I always thought it was pretty quick, nothing special but up to par. This past week after spending some time with a friend of mine I realized his 1990 LX 5speed has alot more power.... Both of are cars are practically stock with the exception of aftermarket exhaust.
The only think I know of is that he has replaced his heads with a new set of OEM heads due to a loss in compression... so Im thinking maybe I should do a compression check on my heads too?
Why else could he be hitting higher RPM's faster and be making more power/speed then me?
Any Ideas?!
Any Ideas?!
RE: Confused
look at the diff in miles! why did he replace his heads with oem? you canget a set of gt40 heads pretty cheap and a good cam then you will smoke his A$$!!!!!!!! i dont know the exact numbers but the lx dosnt weigh as much as the gt!
RE: Confused
have you done all the cheap/ freebie mods? bumped timing short belt, k+n, c+l ? these are cheap and a fairly decent boost. any chance he has gears and doesnt know it? compare his rpm at a certain speed to yours maybe he does but it will be a quik comparison
mrappe
09-26-2015 10:16 AM
mungodrums
09-22-2015 08:36 PM
