Gasket sets?
Gasket sets?
I am doing a gt-40 h/c/i swap next month and I was wondering from the ppl who have tore into their motors before if there was a place or company that sells a gasket set that includes most or all of the gaskets Iwill need for the swap.[/align][/align]Or do I have to buy them all individually?[/align]
RE: Gasket sets?
you can order felpro kits for your application just specify head set..and only thing seperate you'll need is oil pan gasket and rear main and timing cover set..if re gasketing the whole block..if only doing an h/c/i a head set is all you'll need..I like to piece together my stuff as I can pick and choose the best of all worlds
RE: Gasket sets?
I like the metal reinforced reusable valve cover gaskets, 1 piece rubber reinforced metal/rubber pan gasket.....and fel pro timing cover gasket kit....as for head gaskets fel -pro 9333pt-1 I believe are the head gaskets that'll work for you..I use ones for aluminum heads so I'M DIFF THERE....and as for intake fel-pro 1250 is what I use
