how do i seperate the h-pipe from the headers?
Old 03-01-2008, 01:13 AM
93StreetFox
93StreetFox's Avatar
Default how do i seperate the h-pipe from the headers?
i'm replacing the stock h-pipe and headers. i have the headers unbolted and theres movement from the h-pipe but im not seein how to seperate the h-pipe from the headers, it looks like theres just a stud coming through the top of the clamp
93StreetFox is offline
Old 03-01-2008, 02:31 AM
flyinghigh2k8
flyinghigh2k8's Avatar
Default RE: how do i seperate the h-pipe from the headers?
From underneath the car there should be two bolts holding on each side of the exhaust, rite at the cats.
flyinghigh2k8 is offline
Old 03-01-2008, 07:05 AM
nitrous_bob
nitrous_bob's Avatar
yeah you need a long extension, and swivel helps too
or just cut them if your gonna ditch threm, w/ a sawzall, might be easier
nitrous_bob is offline
Old 03-01-2008, 08:47 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
remove all bolts and full the flanges off the studs and make sure the exhaust hangers for the h-pipeeither not still in the holder but what you really have to do is once all bolts are removed kind pull back and down on the h-pipe to remove it
mjr46 is offline
Old 03-01-2008, 09:25 AM
Hung Like a Stang
Hung Like a Stang's Avatar
ORIGINAL: 93StreetFox
With a lot of cussing!
I just had to do that, I don't know if it was stock since I have an aftermarket h-pipe i that didn't install, but the bottom bolt was ridiculously long, had to try 3 different deepwells, and then ofcourse, rusted tight.
I'd say cut off wheel and/or a lot of pb and/or torch.
Hung Like a Stang is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Roxon68
03-17-2016 08:13 PM
junior04
09-28-2015 10:53 AM
09-24-2015 09:18 PM
BrantleyS550
09-14-2015 04:18 PM
Quick Reply: how do i seperate the h-pipe from the headers?
