hesitating, back fireing, and no power
Old 03-01-2008, 03:13 PM
blackknight1456
blackknight1456's Avatar
Default hesitating, back fireing, and no power
ok i have an 87 mustang gt i just got done putting a trickflow track heat intake upper and lower on my car and know my car lacks power and i dont mean just a little bit it lacks alot of power it hesitates when i step on it and it will back fire some of the time it did this a little bit before i did the intake but know its horrible what could it be
blackknight1456 is offline
Old 03-01-2008, 03:30 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Default RE: hesitating, back fireing, and no power
Did you pull out your dizzy? You might want to check you timing and make sure all of your vaccum lines are connected.
projectresto83 is offline
Old 03-01-2008, 03:33 PM
Bullitt91
Bullitt91's Avatar
what kind of exhaust do u have could be a plugged cat if you have them
Bullitt91 is offline
Old 03-01-2008, 04:16 PM
Alero99
Alero99's Avatar
check TPS EGR fuel pressure ect ect.
i have a very similar problem but mine only starts to occur after the car gets warmed up
my dizzy is off by a bit i have to pull it and install it the right way
Alero99 is offline
Old 03-01-2008, 04:46 PM
blackknight1456
i just put brand new cats on it so it cant be the cats and the timing is dead on i already checked that
Old 03-01-2008, 04:52 PM
aode08
aode08's Avatar
is your MAF Straight up and Vertical? NOT LEANING LEFT OR RIGHT, even a little bit?
Did you tighten your lower intake with the torque spec procedure?
aode08 is offline
Old 03-01-2008, 05:00 PM
blackknight1456
no its an 87 it doesnt have a maf so thats not a problem at all
Old 03-01-2008, 05:03 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
so your timing is dead on??? sure the balancer hasn't spun a little making you think your timing is dead on when actually it's not?? just a thought
mjr46 is offline
Old 03-01-2008, 08:32 PM
projectresto83
M.A.D. Motorsports
ORIGINAL: mjr46
Kinda sounds familiar doesn't it Mjr lol. Pull off your dampener and set the key in the crank at exactly 12 oclock and see if you are still on plug #1!. Thats what I had to do just to find out my TDC is at 30 deg on the balancer at the moment.
Old 03-01-2008, 10:26 PM
Novipowered5.0
Novipowered5.0's Avatar
Timing is off.
[ul][*]Disconnect the coil wire.[*]Pull the #1 spark plug[*]Have someone bump the starter while you hold your finger over the hole[*]Once you feel pressure stop and look at the pointer over the balancer[*]Remove dizzy cap and verify that the rotor is right at #1 plug wire.[*]If it is not you will need to turn the engine back or forth at the crank and reinstall dizzy.[/ul]
Novipowered5.0 is offline
Quick Reply: hesitating, back fireing, and no power
