Crank Throw Difference
With the firing orders of the H.O. (13726548)and the older pre 83 firing order (15426378)isn't the crank throw different and its not just the cam? Someone on here toldme in another thread that they are the same and it just seems impossible to me that they can be. The cam and the crank throw have to correspond to make the motor run correctly right.
RE: Crank Throw Difference
the crack is exactly the same.
if you look at the firing order itself, its kinda self explainatory... the order ov events just swaps the compression stroke for the exhaust stroke, via cam timing
13726548
15426378
see the 4 cylinders that swap locations in the firing order are phased exactly 180° through the order.
13726548
15426378
Yes I knew about the 4 cylinders that are swapped. It just didn't sound right. Thanks guys, just wanted other opinions.
Another question then, why is it that after I do the roller conversion that I can't use regualr roller cams with the spider plate and dogbones and have to use a small base base cams? I would love to be able to use the trick flow stage 1 cam but I don't want to have to spend over $500 for the linked lifters.
Thats why the conversion kit comes with the bolts for it that you have to drill and tap the holes.
This kit
http://store.summitracing.com/partde...p;autoview=sku
This kit
ORIGINAL: AdderMk2
13726548
15426378
13726548
15426378
ORIGINAL: projectresto83
There is a cheaper way out though, there is nothing special about that 83 block, why not get a usedroller block. They aredime a dozen,they can be had for $100 for the smart shopper.
