Kenne Bell minus an H/C
I know this might be a dumb idea but i dont feel like really gutting my engine. I plan on buying a Kenne Bell Blowzilla 2.1L twin screw supercharger in the coming spring but I dont want to put new heads and a cam in. The whole idea of the rooted twin screw from kenne bell is its a bolt on and go application and they claim you dont need any pricey upgrades like a new cam or heads for you to get pull out of it. Is this a super bad idea or can I get away with it? thanks
RE: Kenne Bell minus an H/C
I got one on my 94 and through an auto on a mustang dyno had just under 300 whp on 9 psi and 350 lbs of torque with a very broad powerband, i got a lightning mass air accell 36 injectors 255 walbro pump and aeromotive adjustable regulator with a good dynotune. If you only run 6psi you can get away with just an fmu.
put it on and run it, everyone is so worried about a tune which is the biggest load of ****. kb makes their kits for a stock 5.0. just dont drive it really hard for like a week so the computer can adapt. youll be surprised on what the stock ecu is capable of.
ORIGINAL: silver91gt
spending the $3000-$4500 on a kb, supporting mods, and tune, makes 300RWHP seem disapointing.....[:'(] or is it just me
and sence there stock heads, i thought you could throw more boost at them?
like 13 or so
like 13 or so
It is a lot of money for 300whp, but it's also a more simple install than heads/cam. I personally did h/c before a KB so I wouldn't have to take the KB off once it's on there. In my opinion if you're not gonna ever touch the motor and want boost go with a turbo, turbos make sick power even on a stock 5.0 engine.
A guy on another forum ran 11psi on a 1.5L KB kit and made right around 300whp with stock maf, tb, etc. and with traction it would have run 12s. I think even at the same boost level the 2.1L kit will make more power though.
