Heater core Hoses
Old 03-12-2008, 12:31 PM
cholericfc
cholericfc's Avatar
Default Heater core Hoses
My heater core hoses in the engine bay are leaking coolant all over the backside of my engine.
I've confirmed this with the reving of the engine and coolant squirting out right at the hoses end.
WHATS the best and easiest way to replace these hoses???????
IS IT going to be a mess? should I even try to NOT make a mess?????
I hope this fix takes 30mins....... Any suggestions would be much appreciated, thanks in advance!!
cholericfc is offline
Old 03-12-2008, 01:24 PM
JamesIngerman
JamesIngerman's Avatar
Default RE: Heater core Hoses
it is going to be a mess no matter what you do....... i replaced mine when i first bought my car i bought the hoses from advance auto parts because it was the cheapest at the time i eventually bought the ford racing silicone ones . they seemed to fit alot nicer... hope this helps
JamesIngerman is offline
Old 03-12-2008, 01:27 PM
ponyboy302
ponyboy302's Avatar
im pretty sure if you let the engine cool open the rad cap let the pressure out ..if you can squeeze the hose the water has settled and shouldnt come pouring out so it wont meake too much of a mess .. as for the rest hope you have lil hands lol
ponyboy302 is offline
Old 03-12-2008, 01:36 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
pull over the grass and you won't see the mess......replace hoses and bleed system properly when done until you have good heat
mjr46 is offline
Old 03-12-2008, 04:13 PM
cholericfc
cholericfc's Avatar
bleed the cooling system... when i put the motor in - the cooling system worked fine.
Old 03-12-2008, 04:14 PM
cholericfc
cholericfc's Avatar
how do u bleed a cooling system?
Old 03-12-2008, 06:41 PM
thedude
thedude's Avatar
After you replace the hoses, start up the car, and squeeze the upper radiator hose. That will bleed out any air bubbles. Also, if you take off the throttle body, it will be easyier to replace the hoses. While your at, it summit sells a whole set of Ford coolent hoses for about a hundred bucks. Not a bad deal. Also they are baby blue.
thedude is offline
Old 03-12-2008, 09:53 PM
cleanfitty
cleanfitty's Avatar
Be VERY gentle when yanking the hoses from the heater core, or you'll be replacing the HC next weekend.
cleanfitty is offline
Old 03-12-2008, 10:16 PM
93 LX FiveO
93 LX FiveO's Avatar
^^ LISTEN TO HIM!!!
i made the mistake of turning the hose as i pulled it, and took the nipple off the heatercore with it!!
whats next after that? replacing the heatercore!!
not a fun job...
BE VERY GENTLE.. if its too hard keep re-applying lube and it will budge.
93 LX FiveO is offline
Old 03-13-2008, 09:44 AM
cholericfc
cholericfc's Avatar
i already did rip off the entire return pipe on the heater core when i did the motor swap....... it sucked.. it consumed a whole day to replace it.... this time around i'm taking my time....
Quick Reply: Heater core Hoses
