please help pilot bearing yes i already got it out
Ok after chiseling out my pilot bearing i figured out no autoparts store has the pilot bearing i need. The one they all tried to sell me was to big and it is extremly sloppy on the tranmission shaft. It sounds like i would need a pilot bearing for a 4 cyliner tranmisssion But it does not fit either it is to small to fit in the spot where it goes on but it appeared like it would fit on the shaft
i just got an idea though the 4 cyl one looks like it would fit in the regular bearing if that makes any sense. please help .
RE: please help pilot bearing yes i already got it out
is the race the part the bearing gose in to. theres nothing left where the pilot bearing came out of . i can go take some pictures real quick of the remaining bearing and the end of the shaft.
http://i83.photobucket.com/albums/j3...0/DSCF3415.jpg
http://i83.photobucket.com/albums/j3...0/DSCF3414.jpg
here are the pictures sorry about the qulity. So is the race a bushing or somthing so you can use a fourcly bearing also the inside of the bearing was torn to pices when i got it out
Dude you took out the race and the bearing
You need a pilot bearing and a new race, the proper way to remove the bearing is with a pilot bearing puller.
well that blows i wish i would known more about it before i started. oh well i learned something.
so i would have to ask for a 4 cyl bearing and a race for a v8 then
thanks for help
thanks for help
All the pilot bearings I've gotten before were the bearing/race assembly. Another way to remove them if you don't have a puller(which works better) is to pack the hole with grease, and use a pipe etc(not hollow) that fits snug intside the bearing, and whack it like a **** in hard hits with a hammer, it drives the bearing out hydraulically. It can be a pia though, and a puller is easier to use.
ORIGINAL: 67mustang302
Ill give you some good advice guy,
replace the rear main seal(one piece) while you are there. Remove your old one, clean the lip area with a rag and some alcohol, etc, beer works just fine
Replace it with one from NAPA, (teflon), lube the outer with vaseline before install .
Dont feel bad, you could of busted your crank up but didnt, I bet you had a hell of a time with that chisel
