Strong gas smell after sitting......
Old 03-20-2008, 04:16 PM
DoctorD415
DoctorD415's Avatar
Default Strong gas smell after sitting......
Car is kept in the garage at night, and in the morning there has been a gas smell after being in there overnight, and it has gotten kind of strong a few times lately.
Its an 85 carbed. Not sure if its leaking or anyhting but ive checked around good. I've check all connections to the carb, and fuel pump, i've also checked around the gas tank and neck a bit visually and saw nothing, and there have been no signs of leaking on my garage floor?
Are there any spots on these mustangs where there are ususally leaks or rust build up that will cause a leak. Any certain spots i should check? I'm not sure if it will naturally smell a little bit like gas, but i just wanted to double check. Any help or ideas on searching for a leak would great. Thanks in advance.
DoctorD415 is offline
Old 03-20-2008, 05:35 PM
aode08
aode08's Avatar
Default RE: Strong gas smell after sitting......
check the filler neck gasket and rubber seal to tank
aode08 is offline
Old 03-20-2008, 05:49 PM
Dandy74
Dandy74's Avatar
check the secondaries for fuel. If the floats are set to high they can drip at times with the vehicle not running Also check the evap canister if its got one for raw fuel.
Dandy74 is offline
Old 03-20-2008, 06:48 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
IF YOU HAVE REMOVED THE EVAPORATIVE EMISSIONS THEN THE VAPORS WILL JUST VENT TO ATmosphere which is what you may be smelling..and or make sure there are no leaks in the tank or neck and any lines
mjr46 is offline
Old 03-20-2008, 10:47 PM
DoctorD415
DoctorD415's Avatar
ya smog and whatnot have been taken out of car. That would have an effect on the the gas smell?
Old 03-21-2008, 01:59 AM
ptown87
ptown87's Avatar
I removed all the smog and emissions bull**** and my car has a tendency to smell like gas. It probably isn't any to be too concerned about.
ptown87 is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
10-01-2015 05:13 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Strong gas smell after sitting......
