95 gt 5.0
95 gt 5.0
need help, my car doesnt always start, its turns over but doesnt start, i tryed to replace my distributor but nothing, same problem, any ideas, when i was on the freeway i was going about 60mph and when i went to give it gas my rpms went to 0 and it was like i was out of gas, but my car never turned off or died, and about 3 seconds later my rpms went back to normal.......someone help
RE: 95 gt 5.0
ORIGINAL: fastford95
try putin in a new fule pump in the gas tank. and check the fule filter
If you believe it is fuel you need to verify it, you have to get a fuel pressure gauge and connect it to the fuel rail. You will want one with a long enough hose on it so you can tape it to the windshield. Start and drive the car and record your pressure when you have the problem. Your base pressure should be approx. 39 psi at idle. Also when the car doesn't start, did you listen for the fuel pump?
RE: 95 gt 5.0
y not just change the filter if that dont work then change the pump save him money if is just the filter
