ac control???
ac control???
my ac and everything is working but now i can't get it to come out of the vents it just stoped it still comes out of the defrost and the ground but its not coming out of the main vents? ne ideas ???? tHANKS iN aDVANCE
RE: ac control???
may have a bad switch assembut I 'd check the line that goes from switch to vaccum motor for the vent control...good possibility it has a ruptured diapram in the motor or broken line... you'll have to crawl under the dash and find the correct vaccum motor
RE: ac control???
ORIGINAL: hayden
Mine did the same thing a few months ago... Check all of your little plastic vaccum lines. One of mine was broke and all i had was air coming out of the defrost vents
RE: ac control???
i just had my dash out and painted it and it was workin fine before that when i was takin it out there was a vacuum line behind where the glovebox is and it unpluged and it made a wush but i pluged it back in and when i was done and put everything back together when i turn it on the ac it just blows out of the drfrost but when i turn it to floor it blows out of the floor it just won't blow out of the vents so is there a way i can reset the vacuum line??
RE: ac control???
there are three vaccum motors on there did you check all three and make sure you got the right one??? if they were crossed it'd open a door at the wrong time with the position not corresponding to the function
