Some H/C/I questions
i'm finally going to be doing a h/c/i on my car. i just scored a pair of edelbrock performer heads from a buddy. also picked up an already ported performer rpm II intake. i'm most likely going to run a e303 cam (any other suggestions?) because i hear you canhave no more than .512 lift on a stock bottom end.
with that said, keep in mind im going to be supercharging the car eventually with no more than 8psi but will also be running n/a for a while with the new setup. so here are my questions: what size MAF? what size TB? do i needa bigger fuel pump and bigger injectors for running n/a or will i be fine for now? i was thinking a 76mm MAF and a 70mm TB but correct me if i'm wrong.
thanks in advance and feel free to give any other advice and suggestions
RE: Some H/C/I questions
I think you would be better off with a dual pattern cam from comp or another company if you are going to supercharge. They will make more power with the supercharger. But if you still prefer an frpp cam i would go with an f cam instead of the e. it will get the air in and out of the engine a little better and it was designed for superchargers if i'm not mistaken. Plus it has a nicer sound i think. But thats just my opinion. Hope this helped you out a little.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
