Neeed Hellppp!
Old 04-09-2008, 07:58 PM
95stang5.0
95stang5.0's Avatar
Default Neeed Hellppp!
Ok so I did the t-5 swap last winter, ever since i did it there is a clunking noise like something is lose sometimes when i let off the clutch. Its hard to explain, but if u make the car jerk a little bit you can hear it. I bought everything new except a used alum driveshaft. Could it be the u joints? Or what else do you think it could be. The tranny mounts new and thight im not sure.
95stang5.0 is offline
Old 04-09-2008, 08:24 PM
stang8689
stang8689's Avatar
Default RE: Neeed Hellppp!
could be U joints or throwout bearing, but that would only do it when clutch is in
stang8689 is offline
Old 04-09-2008, 08:31 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check the u-joints first but make sure that no exhaust parts/pipes are positioned close to the driveshaft
mjr46 is offline
JackMims
4 Cylinder NA and Turbo
03-09-2015 12:21 PM
code3GT
AmericanMuscle.com
06-04-2013 09:55 AM
plug72
20
05-15-2013 06:53 PM
lovemystang2000
03-24-2013 08:02 AM
Quick Reply: Neeed Hellppp!
