Alignment Shop Grinded Out Mounting Holes on Strut Tower, Good or Bad?
Old 04-18-2008, 08:50 PM
C_A
C_A's Avatar
Default Alignment Shop Grinded Out Mounting Holes on Strut Tower, Good or Bad?
I had my car aligned recently. The shop grinded out the mounting holes on the top of the strut tower.
Are there any potential problems in doing this?
I was told this was a needed repair in order to set the camber but why would this be needed?
C_A is offline
Old 04-18-2008, 08:54 PM
C_A
C_A's Avatar
Default RE: Alignment Shop Grinded Out Mounting Holes on Strut Tower, Good or Bad?
Here is a pic.
[IMG]local://upfiles/76380/66A2FFE5EC9C4AECB557980C59BC5AB7.jpg[/IMG]
C_A is offline
Old 04-18-2008, 09:03 PM
NYMustang50
NYMustang50's Avatar
Well if you ask me yea i wouldnt bring my car back to them and its too late now.
NYMustang50 is offline
Old 04-18-2008, 09:18 PM
Boss_Hotrod
Boss_Hotrod's Avatar
I believe that is BS. Every time I aligned a car with a front strut I was to grind out the mounting holes on the lower strut mount where it bolts up to the spindle.
Boss_Hotrod is offline
Old 04-18-2008, 09:23 PM
LX 90
LX 90's Avatar
Yeah to adjust camber you can grind out the holes on the lower strut mount or the upper. It looks 100% better when you do it on the lower strut mount but that guy was prolly to lazy to remove the strut.
LX 90 is offline
Old 04-18-2008, 09:25 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
looks like they slotted it to get caster adjustment......and if you ask me it looks like a hack job.....as long as it stays in place you'll be fine.......but honestly there is a better way to have done it and look neater....obviously they are clueless about mustang technology...they make caster camber plater to do what they did but it only looks cleaner like this...see: look on top of the strut towers
http://i242.photobucket.com/albums/f...inished001.jpg
mjr46 is offline
Old 04-18-2008, 09:27 PM
mjr46
mjr46's Avatar
if you have to gring anything from fac settings then somrthing is either worn out or bent[:@][:@]
mjr46 is offline
Old 04-18-2008, 09:48 PM
C_A
C_A's Avatar
ORIGINAL: mjr46
Staying in place was a concern I had. I was thinking that adding the caster/camber plates whenever I had the $$$ might help with staying in place because I believe you have to drill an additional mounting hole. ????
C_A is offline
Old 04-18-2008, 09:51 PM
C_A
C_A's Avatar
ORIGINAL: mjr46
I was wondering what is bent. Based upon how much they moved the upper mount for the strut, it looks like something has bent a considerable amount.
C_A is offline
Old 04-18-2008, 09:54 PM
mjr46
mjr46's Avatar
ORIGINAL: C_A
ORIGINAL: mjr46
either a strut or control arm or subframe issue
mjr46 is offline
Quick Reply: Alignment Shop Grinded Out Mounting Holes on Strut Tower, Good or Bad?
