can't get timing right
just got a new distibuter and i am running the car but the timing is off a little it is hesitating but i have tried turning it but i can't get it right. I don't have a timing light ether. it has the msd package and wiring harness on it 2.
RE: can't get timing right
you have to remove the spout before setting base timing but you need a timing light = no other way and you may have to use a wire brush to clean off balancer so marks are visible
if you know you are on the right tooth, for a street tune - if you have a vacumn gage -
remove the spout and advance or retard the distributor till you get the highest vacumn. highten down and try it out.
We set the number one b-for we put the motor in the car. i pulled the trany and put in a new clutch kiut and put on a shatter gaurd and drove it and could feel the hesitation i guess i will go get the timing light thaanks
i tried working on my timing today, however when i remove the spout connector, the car wont even start up. any ideas?
i followed those instructions on how to restab a distributor, and now its running better than it was before but still not perfect. and the distributor is really turned closewise alot, and timing looks advanced alot. can i be a tooth off or something. maybe i didnt start exaclty at TDC?
i figured checking the timing with the spout connector, increases it 15-20degrees. (i read somewhere im pretty sure) so its probably really at 0 degrees then. im thinking i need to advance it some more. however the distributor wont turn anymore bc the spout connector will be facing the front of the car.
djsprinklesnjo, When you say you unplugged the spout connector, did you actually unplug the ignition control module? (grey rectangle thing on the distributor). Sorry if i misunderstood you, something seems off.
Also, is kgriffithanddjsprinklesnjothe same person?
