rear is toast
rear is toast
well i finally realized how bad the rear is today. i put her up on the lift to rotate my driveshaft and i grabbed the wheel to spin it so i could get the top bolts on the driveshaft. i went to spin it forward and it felt like the car was in gear even though it wasnt. finally got the wheel to spin and it was still very very hard to spin and only one wheel was spinning. i spun it backwards and it spun fine both wheels at the same time the way its supposed to. so there is something really bad in there. i guess its time to do the 3.73's in the 8.8 i have sitting under the bench at work
RE: rear is toast
what are you talking about fox with a working ebrake? i guess you guys dont know how to adjust it so it works. mine has always been nice and tight.
and yes thats exactly what i thought was wrong bad bearings.
RE: rear is toast
ORIGINAL: 1985stang
there's a little bolt with a nut on the end that you can tighten to adjust it. i tried to do mine a while ago, but it didn't fix anything. probably stretched cables, but idk.
