hey fellas quick question
Old 04-22-2008, 10:40 AM
50foshow
50foshow's Avatar
Default hey fellas quick question
hey i got a 88 gt and I picked up one of them harnesses that plug into to mass air sensor and goes to the ecm for converting it to mass air after I do that what else should be done thanks felles
50foshow is offline
Old 04-22-2008, 04:03 PM
aode08
aode08's Avatar
Default RE: hey fellas quick question
DO a search for MAF CONVERSION
aode08 is offline
Old 04-22-2008, 09:16 PM
JamesIngerman
JamesIngerman's Avatar
im not to sure im still knew as well but i know you need the mass air meter
JamesIngerman is offline
Old 04-23-2008, 01:05 AM
cheetha94607
cheetha94607's Avatar
needs for conversion is harness mass air sensor and computer for mass air.
cheetha94607 is offline
Old 04-23-2008, 03:09 AM
FoxGT
FoxGT's Avatar
You don't need a mass air harness to do a mass air conversion...
You can just run a couple extra wires to the computer. I just finished the swap on a friends car about 2 weeks ago & the only thing I had was a mass air meter from a junkyard car & picked up a remanufactured a9p eec from the parts store. required running 4 wires through the firewall grommet (used two screw drivers to spread it open) pinning two into the computer, splicing for power & moving a couple pins to different locations. Took about 20 minutes max with a wiring diagram to tell which pins were for mass air.
FoxGT is offline
richard1027
09-09-2015 07:23 PM
richard1027
09-08-2015 01:24 PM
GimpyHSHS
08-29-2015 06:30 PM
StangMuscle
08-12-2015 07:27 AM
mustangfan305
08-07-2015 11:09 AM
Quick Reply: hey fellas quick question
