electrical problems still about to give UP!
Old 04-23-2008, 03:48 PM
Alero99
Alero99's Avatar
Default electrical problems still about to give UP!
i don't have
HVAC Motor
Turning Signals
Reverse Lights
Rear Defroster
They all worked when i first bought the car and the turning signals reverse lights and defroster all crapped out together then the HVAC motor went on me WTF!
i just replaced the ignition switch and NOTHING! i've been chasing down wires and studying diagrams for ****ing months and there is simply no logical reason i can find why these ****ing things stopped working.
before i ghost ride this ****ing car back into the factory where it was made DOES ANY ONE... ANY ONE have anyyyy idea what else could be causing all this **** to just suddenly stopp working in my car?
Alero99 is offline
Old 04-23-2008, 04:05 PM
Dilireus
Dilireus's Avatar
Default RE: electrical problems still about to give UP!
Stupid question...did you check the fuses?
Dilireus is offline
Old 04-23-2008, 04:10 PM
camaroeater
camaroeater's Avatar
I feel your frustration man.[:@] Mine quite a month ago...I changed the flasher and checked the connecitons like 4 times. I ended up with my car at the Ford dealership, cause I got caught in bind for another issue, so i let them take a look at it. I turned out to be a badTurn Signal Switch and fryed wire harness that plugs into switch. Switch was 210.00, wire harnes 30.00 plus labor it was 500.00...nearly killed me. Signals work and I have a New turn signal lever but I broke.
Things it could be:
Connections dirty in switch where lever makes contact or loose wires toswitch
Turn Signal Flasher
Ignition Switch (which you did)
Turn Signal switch
camaroeater is offline
Old 04-23-2008, 04:43 PM
Alero99
Alero99's Avatar
All fuses Checked and Re Checked... wires everything is attached and they all lookall pretty like brand new...
Flasher is good
question camaro eater what were they acting like before they crapped on you?
Alero99 is offline
Old 04-23-2008, 05:40 PM
camaroeater
Starting a month ago they started blinking faster on instrument panel and outside car. It seemed they were blinking at a better speed and I was happy. Then a week before they stopped working, the flash outside the car and on the insturment panel was lighting up and going out way too fast. So fast you could only see the arrow on the instrument illuminate for a split second and outside the car the bulb would flash and go out to quick. I rather have somthingobvious go out then this ****. PS pump, alternator, battery ect.
Old 04-23-2008, 05:50 PM
Alero99
Alero99's Avatar
yea well mine before they crapped out blinked PAINFULLY SLOW
Alero99 is offline
Old 04-23-2008, 08:17 PM
HACKGT350
HACKGT350's Avatar
ok turn signals and reverse lights are on the same fuse i dont know about the rear defroster because i dont have one. you need to see if you have power going to the fuse itself for those. do you have a test light or dmm?
HACKGT350 is offline
Old 04-23-2008, 08:35 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
man a simple understanding of electricity 101 can go a looooooooong way[&:]......with a wiring diagram a test light or dvom you should be able to find prob in an hour or two
mjr46 is offline
Old 04-23-2008, 08:37 PM
HACKGT350
HACKGT350's Avatar
yeah classes really really helped me with that
Old 04-24-2008, 01:03 AM
Alero99
Alero99's Avatar
i do have a test light actually... im guessing ground it and stick the lead point into the fuse while the ignition is in the on position?
Alero99 is offline
Quick Reply: electrical problems still about to give UP!
