some stupid questions
Hey guys,
I have a 19905.0 and had the radiator and A/C replaced the other day.
I can't stand when **** is crooked or not fitting as well as it should, but if it's not really hurting anything I'll just leave it as is.
Here's my question:
1. does it matter if the radiator is crooked? (driver side is about a half an inch closer to the firewall than the passenger side.) Fan seems to clear just fine and the radiator is definately secure.
2.On thenew a/c lines the high pressure (red) cap is digging into the hood insulator. Is there a way to have the lines bent or repositioned to sit lower for better clearance?
thanks
Here's my question:
thanks
RE: some stupid questions
as long as the radiator isnt massively crooked it shouldnt matter. its more of just the bugging you inside factor more than anything. just make sure that your fan isnt anywhere close to your fins.
as for your a/c lines i would not recommend bending them. if anything cut out that piece of hood insulation so the cap will sit in there better.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
