t-5 transmission fluid thru the shifter
Old 05-04-2008, 09:32 PM
1995mustang818
1995mustang818's Avatar
Default t-5 transmission fluid thru the shifter
is this posible i changed my tranny today and put the fluid thru the shifter is this ok or no ???
thanx
1995mustang818 is offline
Old 05-04-2008, 09:35 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: t-5 transmission fluid thru the shifter
unless you have the fill plug open how are you to know when it's full or not???[&:]
mjr46 is offline
Old 05-04-2008, 09:39 PM
FuzzyDiceRule
FuzzyDiceRule's Avatar
2.5 quarts isnt it, everyone says to fill through the shifter hole, so...[&:]
FuzzyDiceRule is offline
bighungrymatt
bighungrymatt's Avatar
^ what he said, its ok to do it through there, but you want to make sure it comes out the fill plug. I have always just filled mine through the fill plug with a pump
bighungrymatt is offline
Old 05-04-2008, 10:11 PM
AdderMk2
Banned
AdderMk2's Avatar
before I put my new shifter, I drilled and tapped a hole in the base plate, for a fill plug. T5 trannies take 2.7qts.... so I just drain it, plug it, and fill'r up!
AdderMk2 is offline
Old 05-04-2008, 11:57 PM
silver91gt
silver91gt's Avatar
leave the fill plug out and fill through shifter till it comes out.
silver91gt is offline
Old 05-05-2008, 08:42 AM
HACKGT350
HACKGT350's Avatar
keith why did you drill and tap a drain hole? they already have drain holes in the bottom and a fill hole. drain it and then put the drain plug back in then remove the fill plug fill it through the shifter till it starts dribbling out the fill hole put the fill plug in and your good to go once you rtv your shifter in place
HACKGT350 is offline
Old 05-05-2008, 09:06 AM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: HACKGT350
reading comprehension owns you...
I drilled a hole in the base plate of my shifter...
that way I dont have to remove the whole shifter every time I change my fluid... I just unscrew a plug!
AdderMk2 is offline
Old 05-05-2008, 09:07 AM
golden_eye
golden_eye's Avatar
ORIGINAL: HACKGT350
I think you may have misunderstood? He's saying he put a fill plug in the base of his shifter which would let him fill it from the top without having to take the entire shifter off. Sounds like a good idea to me since it would be easier to fill.
EDIT: Adder types quicker than me, lol
golden_eye is offline
Old 05-05-2008, 10:33 AM
Jfsram
Jfsram's Avatar
B&M shifter also have that feature. Fill hole through the shifter mechanism.
As nice as that sounds. You still need to open the factory fill plug to let you know when it's full.
Jfsram is offline
Quick Reply: t-5 transmission fluid thru the shifter
