Procharger powerpipe
RE: Procharger powerpipe
Lol thats why I am asking. I'm using the same small filter Samseed used but I want to try to take it a step further this summer. I was wondering if anyone had ever SEEN it done.
What if it were to go towards the engine and downwards...I know its alot of extra pipe ducting but there is definatley room to get it away from the rest of the engine. If the blower has to draw air past the exhaust, lets say 3-4 inches(but still in a steel/aluminum pipe), what kind of effects could it have on performance?
Has anyone heard from Samseed recently? Maybe I'll shoot him an email.
ORIGINAL: ColdCityMustang
I did have a possible solution though. I posted about it awhile back. I was about to do it when I sold the car. But I know that it will work, but will take some effort on your part. Let me see if I can find the old post.
Found the old post and pics. Like I said, there was no way to get the actual filter into teh fenderwell. Even with correct piping and a sharp turn it wouldn't fit without SEVERELY restricting airflow. But you can make it so that it sucks in cooler air. Here's how:
First swap to the smaller APC filter like I did (which you already did anyway.) It's only smaller in length, it actually has a rather large surface area so it's not restrictive. Then cut a hole into the inner fender. Instead of putting the filter through the hole you're just going to leave the hole wide open. make sure it's a decent size. After that, just sort of "box off" the air filter so that it draws ait from the fenderwell hole instead of the engine bay. Similar to how this CAI works:
So using a similar setup, you can create a barrier between the engine and the filter. And it will draw air through the hole in the fender. It's not quite as good as putting the filter in the fender, but it's a hell of a lot better than what came with the Procharger. Here's what my filter looked like. Then all I had to do was cut the hole and box it off.
ORIGINAL: 94StinkinLincoln
samseed, why did you sell it??? i havent heard from ya in a longtime.
