Anyone install a oil pressure switch??
I have a oil pressure switch on order along with a temp sender for the gauge. The temp seems straight forward just unscrew and screw the new one in. But the oil pressure switch I am unsure as to where it is located and how to romove it from top or bottom of car
RE: Anyone install a oil pressure switch??
The oil pressure sender is on the front left side of the engine just above the oil filter, it a small canister shaped piece on a 21/2"extension with a single wire lead on it. It just threads out of the extension via a hex head on the back of the canister by the thread, (1/2" I believe).
ORIGINAL: Gronk72
Actually just went and dug my old one out of my toolbox and it is a 9/16 wrench that you'll need so I stand corrected. Yes, at the top of the threaded fitting on the sender where it attaches to the extension is a hex head 9/16. Sorry about that man.
ORIGINAL: Gronk72
The sender canister itself is about 2" by 2"(not including the fittings) and tappered at the top with a single push on style wire lead. By the way, I recomend you just removed the sender where it attaches to the extesion a leave the extension, gives you a little extra clearance.
