408 question
Old 05-15-2008, 12:00 PM
five0fm
five0fm's Avatar
Default 408 question
hey guys ive been talking to some of my mechanic friends and they said i should all go 408 stroker althought they dont agree on compression. im wondering if there is a ballpark range of hp with a 408 stroker 200-225cc heads (prob afr) holley systemax and custom cam and 9:1 or 10:1 or 12:1..thanks guys
five0fm is offline
Old 05-15-2008, 03:24 PM
.boB
.boB's Avatar
Default RE: 408 question
A lot depends on your cam and where you drive. What you really want to know is effective cylinder pressure, or cold cranking pressure. You want that to be in the 180-190psi range.
My static compression is 10.8. With a big cam and high altitude, I usually run mid grade without any problems.
.boB is offline
Old 05-15-2008, 05:16 PM
ruger311
ruger311's Avatar
go 408 with 225s and go with like 9:1 comp and turbo the bitch
ruger311 is offline
Old 05-15-2008, 05:21 PM
WhiteWindsor
WhiteWindsor's Avatar
You can go as high as want. You need to decide what your plans arefor thethe engine. What will it be used for?Example's: will it be fortrack,street,track/street,show,weekend cruiser,trailor queen,future FI,etc.. Be honest with yourself about it's use then decide what kind of compression you want.
WhiteWindsor is offline
Old 05-15-2008, 05:40 PM
wrenchturner75
wrenchturner75's Avatar
remember you can get decent power numbers with a 9.1 ratio and not have to run the hot sauce!
wrenchturner75 is offline
Old 05-15-2008, 07:20 PM
5spd GT
5spd GT's Avatar
You will have to go with a different intake and larger.
11:1 is a fairly good cut-off point for pump gas.
Custom camshaft will assist you greatly.
5spd GT is offline
Old 05-15-2008, 10:24 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
get a nice set of aluminum heads and keep compression at a pump gas friendly 10 to 10.5 to 1 and you'll be fine
mjr46 is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: 408 question
