Vents
Vents
I have a 94 GT and my vents will not open to allow the air to flow through. The flap in the dash is suppose to open but it doesn't. I check all the vacuum hoses and they are all connected. So, I'm guessing the device that controls the flap in the dash isn't functioning. Can anyone offer suggestions?
RE: Vents
I had a similar problem with my 95 GT. For me, problem was a broken vacuum line under the hood. look under the hood and by the firewall should be some little black hoses on the driver side. There will be this thing that has a bunch of vacuum lines coming out of it and if you look closely, one of them should say A/C i think (If not, its probably the skinniest line) Trace that and check if its broken or disconnected. On my car, I traced it over to the passenger side and there was a T-connection that had broken.
That should be the fix, but either way let us know. Good luck.
if you need more info, see:
https://mustangforums.com/m_4957409/...tm.htm#4957409
or post back here[8D]
Steve@CJPP
CJ Pony Parts
08-19-2015 08:52 PM
