distributor install for an idiot that didn't mark anything
Old 05-22-2008, 04:06 PM
jrt1990
jrt1990's Avatar
Default distributor install for an idiot that didn't mark anything
lol can anyone tell me the best way to go about it?
jrt1990 is offline
Old 05-22-2008, 04:40 PM
Joel5.0
Joel5.0's Avatar
Default RE: distributor install for an idiot that didn't mark anything
EFI Distributor Installation and Initial Spark Calibration
Joel5.0 is offline
Old 05-22-2008, 04:48 PM
z24stang
z24stang's Avatar
I have to thank youJoel5.0,because I did the same thing and your right up helped me.Great info on your site.
z24stang is offline
Old 05-22-2008, 04:50 PM
AdderMk2
Banned
AdderMk2's Avatar
apparently you guys havent figured out how to use the tech articles
https://mustangforums.com/m_3264510/tm.htm
AdderMk2 is offline
Old 05-22-2008, 06:03 PM
86whitepony
86whitepony's Avatar
yeah seriously those tech articles helped me so much, thanks adder for that write up helped me alot while stabbing that dizzy
86whitepony is offline
Old 05-24-2008, 09:58 AM
jrt1990
jrt1990's Avatar
ok we marked where cylinder one is on the distributor, took the cap off, put cylinder one at top dead center, pointed the rotor towards cylinder one, made sure that little hex thing at the bottom was straight up and down and it will not drop in....what can i do?
jrt1990 is offline
Old 05-24-2008, 10:00 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
+1 on the tech articles. They have been very helpful in giving me ideas and info for my build.
projectresto83 is offline
Old 05-24-2008, 10:23 AM
jrt1990
jrt1990's Avatar
btw im goin by my haines manual
jrt1990 is offline
Old 05-24-2008, 10:43 AM
AdderMk2
Banned
AdderMk2's Avatar
when you start to push the distributor down, the rotor will begin to turn.
and if it wont go down into the hole.... just wiggle it around a little bit
AdderMk2 is offline
Old 05-24-2008, 11:39 AM
samsonhusky
samsonhusky's Avatar
the oil pump rod needs to go in the hole in the bottom of the distributor that's whats probably keeping it from dropping in. If you look in the hole where the distributor goes you will see the rod it maybe laying agaisnt the side if wiggling don't work what i did was got something and moved it to the center then put the dist in even doing that it may take a few tries good like
samsonhusky is offline
Granatelli Sales
01-20-2020 12:34 AM
cbird1177711
09-02-2015 04:12 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: distributor install for an idiot that didn't mark anything
