power window fix
power window fix
I got the replacement plastic bushings for the motorso Ipulled the door panel off. The power window motor appears to be riveted in place. If I drill out the rivets can I just pull the motor away from the window regulator? Its hard to see back in there.
RE: power window fix
You need to remove the regulator and motor as one. Drill the rivets out and remove. Use vise grips to huld the regulator from moving. Unbolt the motoer and swap. If you don't have rivets or a gun use nuts and bolts. You can get the big daddy rivet gun for $20. Its good to have
^^^^ for real easy mna, i dont even have a speaker hole in my door and i did in in less than 45 min stuff is cake the bolts are 8 mm and your gonna need some duct tape to hold up the window i have a vert so it was a lil harder but over EZ
Just to clarify things a bit, this is a '94 sn95 stang. The three bolts appear to be holding the cover on the motor they're not bolted to the door frame. There are access holes in the door frame to get at the three bolts, but there are also two rivets which I think are holding the motor in place. And yes, the regulator is mounted with rivets.[sm=bicker.gif]
SN-95's are harder, does it look like you can access the 3 bolts that hold it on? If you have to remove the whole thing its kinda a bich cause all the door glass allingments
