Adjustment for hatch?
Old 05-26-2008, 11:45 PM
Slo5oh
Banned
Slo5oh's Avatar
Default Adjustment for hatch?
Hatch doesnt latch too snung to the body, whats the adjusment procedure?
Slo5oh is offline
Old 05-26-2008, 11:46 PM
primetime5.0
primetime5.0's Avatar
Default RE: Adjustment for hatch?
move the stryker down
primetime5.0 is offline
Old 05-26-2008, 11:48 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Another thing may be the bumpers arent in far enough. Mine are set at 3 ribs showing.
Boss_Hotrod is offline
Old 05-27-2008, 06:32 AM
stang8689
stang8689's Avatar
The latch could also be worn
stang8689 is offline
Old 05-27-2008, 06:43 AM
Slo5oh
Banned
Slo5oh's Avatar
Ok thanks, all things I will look at.
Slo5oh is offline
Old 05-28-2008, 02:00 AM
Nerdlinger
Nerdlinger's Avatar
I had a very similar problem... on mine the latch was striking the plastic around the striker area. If you remove the metal panel on the inside of the roof above the rear seats (4 screws) you have access to the 2 bolts that hold the hatch hinges to the car. Loosten these, then with the hatch open, move it around until you get the hatch positioned properly. Then tighten down those two bolts and see if it worked. It's kind of a trial and error thing.
BTW nice car, if I couldn't see mine out the window I would have thought it was stolen...exactly the same even down to the turbine rims
Nerdlinger is offline
cr620
10-03-2022 10:18 PM
baddog671
07-26-2016 01:20 PM
Thunderball
15
11-22-2015 11:49 PM
UrS4
10-03-2015 06:23 AM
winner99
09-30-2015 07:04 PM
Quick Reply: Adjustment for hatch?
