Stick to auto trans swap??
I want to remove my stockT5trans and install a C4auto in my 91 GT.
The car is a factory 5 spd and it has an aluminum drive shaft.
What is involved to get the auto trans mounted and connected to the drive shaft or is it a simple swap, plug and play deal?
RE: Stick to auto trans swap??
I am in the process of doing this swap right now here is a list of what I have ordered so far:
Redneck C4 Transmission with 3500 Stall converter and transbrake
TCI small bellhousing
157tooth 50oz balanced flexplate
Perma-cool trans cooler
6an transmission cooler lines
Dipstick
TCI lighting shifter
My understanding is the factory drive shaft will fit, but I will confirm this next weekend when I actually make the swap.
Dipstick
somewhat simple. the driveshaft will work.
i wanna say i've heard fo issues w/ the switches though, not sure what, and not a big deal.
i don't have any experience doing it though.
ORIGINAL: smythge
Dipstick
Dipstick
That TCI shifter looks awsome i will also be makeing the switch to. Auto's win races
I am putting in a redneck c4 with 3500 stall also.
Dont forget you will need another block plate/dust cover that goes on behind the flexplate. Since the t5 block plate will leave a pretty good size gap at the bottom. I ordered one from summit that will be here tommarow then i can put my transmission in.
ORIGINAL: rush
ORIGINAL: smythge
I was wondering about that, do you have a part number for it? Also how fast did Redneck get the transmission out to you?
ORIGINAL: rush
Took them little over 3 weeks to ship it out then two days to ship it to me. http://store.summitracing.com/partde...p;autoview=sku
part number PMA-PA26445
ORIGINAL: 95stang5.0
Let me know if your selling your manual parts as a kit or piece by piece i have a friend very interested in the t-5 parts.
I took the car apart and rebuilt everything including the trans 3 years ago and the car has been sitting in the garage ever since.
I sort of lost interest in it for a while. LOL
With the power I have I'm just going to destroy the T5. I should be able to build an automatic trans a lot cheaper than buying a Tremec and all the pieces to make it work.
Since I've decided to make the car strip onlyrunning the automatic will be more consistent any way.
