shifter vibration
RE: shifter vibration
Does the vibration go away at higher speed..... my bet is either u-joints or the shaft needs to be balanced. My old frankenstein fox would shake like hell between65 - 75mph but would feel fine anything below or above. Came down to my shaft out of balance and incorrect jerry rigged u-joints..... oh andresulted in the yoke breaking at the tail-shaft so it go a new yoke and shaft in the process.
mine shakes more as I go faster, I just don't want to keep throwing money at the car, it is a big reason I put the new trans in. It needed a new trans any way so no big deal.
U-joint is fairly cheap $15 - $20, especially in comparison to a transmission.... balancing a shaft here in Texas is$30 -$50.
Since the trans is a fresh rebuild I would go ahead and replace the u-joints, mark your shaft, so you can install it the same way, if you still have trouble, install it 90% off and re-test. If the problem continues.... well its time to think about balancing the shaft or having the rear end looked at.
ORIGINAL: brentloftis
ORIGINAL: droptop302
Marking drive shaft when takeing it out why?
junior04
09-28-2015 10:53 AM
