confuessed about clutch adjustment?
ok so i just finished my manual swap and needed help adjusting clutch please (im confuesed)
So when driving it grabshigh (not sure if this is becuase its a stage 3 ram clutch or not) and then when i get on it, you can hear the clutch slip, (i gave it a break in, and it already came with 3k miles onit with the tranny)
so where do i start?
RE: confuessed about clutch adjustment?
stock quadrant or adjustable quadrant.
stocker you just pull up on the pedal and press it it in a few times ti self adjusts.
i fit's a better quadrant... adjust it so it starts to engage about 1 1/2" off the floor
ok so the clutch is fine (i think) durring normal driving, but when i get on it the clutch will slip! HOW do i go about adjusting for this, do i tighten or loosen the adjuster bolt
You said "adjust the nut" so I am assuming you are talking about the cable being adjustable. I just adjusted mine until it was where I wanted it at on the pedal and made sure it didn't slip at all. Kind of a pain in the rear if you have to adjust it more than once cause you have to keep jacking i up, but you could always put it on jack stands so you can adjust/test without putting all that. If its too high on the pedal, I think you loosen the nut... And if its grabbing too low, tighten the nut...
ok i get that. (sorry really new to clutches, so i dont really understand much about them. Will this combat the slipping? or is there something else that will need to be done??
Get a fire wall adjuster. Then just set the cable on the clutch fork so there is little to no slack. So if it is slipping, loosen the adjuster, if it won't disengage, tighten it. I like mine a to work up near the top so when I quick shift, the clutch disengage sooner and I don't have to push it in all the way.
ok so i got all of the slip out of the clutch, and when i get on it all the power is getting through... but i am still smelling a little bit of burning clutch (didnt drive it that much cause i didnt want to ruin the clutch) anythoughts??
junior04
09-28-2015 10:53 AM
