New member with electrical issues!!!!!!
Old 06-06-2008, 09:23 PM
lee_j_94
lee_j_94's Avatar
Default New member with electrical issues!!!!!!
Hey guys,im new to the forum and need a little help with a 5.0 conversion. I bought a 94 lx mustang with the monster 3.8 v6, and yanked it out and droped the 5.0 in. This is my first non fox body mustang and i know i have to have a 94-95 gt engine wiring harness, but what about the computer? The 302 going in the car is out of a 93 gt, will that computer work or did they change the computer when they did the body style? Any info would be very helpfull as this budget conversion has already went out of control. Thanks alot.
lee_j_94 is offline
Old 06-06-2008, 09:26 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: New member with electrical issues!!!!!!
if it's a 93 engine and you plan to install it in a sn-95..you can't use the ecm from the 93 with the sn-95 harness and the 93 engine will need an sn-95 timing cover and water pump installed and an intake from a sn-95 also
mjr46 is offline
Old 06-06-2008, 09:29 PM
lee_j_94
lee_j_94's Avatar
well i have an intake off a 94, but i was unaware that the water pump and tming cover were diff. Is this a must change issue or will it work for now? thanks for the info
lee_j_94 is offline
Old 06-06-2008, 09:33 PM
mjr46
mjr46's Avatar
you'd have to use all the acessories from the 93 ...... either rig up a elec fan set up or fan clutch set up...just depends on how correct you wish the conversion to be
mjr46 is offline
Old 06-06-2008, 09:35 PM
mjr46
mjr46's Avatar
if it were mine I'd use all sn-95 accessories and timing cover and water pump .. that way radiator inlet and out let are matched and correct hoses can be used and then I'd use a fox wiring harness and ecm as the sn-95 ecm when coupled with major engine mods have been detuned and can be tricky at times accepting new mod
mjr46 is offline
lee_j_94
lee_j_94's Avatar
lol, correct to me means it runs. Thanks for your help and i guess i will start looking for a computer.
lee_j_94 is offline
Old 06-06-2008, 09:37 PM
mjr46
mjr46's Avatar
ORIGINAL: lee_j_94
correct to me means it runs and performs the way it was designed too = runs well
mjr46 is offline
lee_j_94
lee_j_94's Avatar
So your saying i should just pull the harness out of the fox body, and use that comp and harness? that would be much cheaper for me
lee_j_94 is offline
Old 06-06-2008, 09:39 PM
mjr46
mjr46's Avatar
that's what I'd do..... but then you'd need a complete fuel management system / long block from the fox....= intake and injectors and all sensors
mjr46 is offline
Old 06-06-2008, 09:42 PM
lee_j_94
lee_j_94's Avatar
Ive got a donor 93 gt, which is where the engine came from. I think i will go that way with it as it seems thats going to be the cheapest way out.
lee_j_94 is offline
Quick Reply: New member with electrical issues!!!!!!
