What causes this?!?!
Old 06-09-2008, 09:14 PM
94RedDevil
94RedDevil's Avatar
Default What causes this?!?!
I start my car up and it acts pretty normal. I took it up the street, there was some slight bogging from like 3-4 grand but nothing other than that. I got it home and it dies. After it dies, it wont start up until the car cools down. Its almost like it runs fine up until operating temp then it dies and wont start. What could cause this?
94RedDevil is offline
Old 06-09-2008, 09:18 PM
HACKGT350
HACKGT350's Avatar
Default RE: What causes this?!?!
whats your timing set at?
HACKGT350 is offline
Old 06-09-2008, 09:20 PM
94RedDevil
94RedDevil's Avatar
like 24 degrees. Before, the guys that did my dyno had my timing at 30 and it was running great
Old 06-09-2008, 09:23 PM
HACKGT350
HACKGT350's Avatar
im gunna assume your talking about total timing? what about your basetiming?
Old 06-09-2008, 09:35 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if the car dies and won't restart untuil it cools down..check for spark if you have none..it could be a bad tfi module
mjr46 is offline
Old 06-09-2008, 09:51 PM
94RedDevil
94RedDevil's Avatar
i'm about to sound like a retard...what is the difference between basetiming and total timing
Old 06-09-2008, 09:59 PM
mjr46
mjr46's Avatar
base is what you initially set it to by rotating dizzy...usually anywhere from stock setting 0f 10 degrees to a max of 15...and total is base + cintrifugal(if it's msd)or vaccum advance or/ computer controlled advance ....optimal total is usually between 34-36
mjr46 is offline
Old 06-09-2008, 10:41 PM
thunderjet429
thunderjet429's Avatar
maybe a tfi module or even a pickup coil.... when it stops running check for spark and fuel pressure
thunderjet429 is offline
Old 06-10-2008, 12:57 AM
FredP
FredP's Avatar
tfi module +1
FredP is offline
Old 06-10-2008, 07:48 PM
94RedDevil
94RedDevil's Avatar
I hooked my distributor up to my old coil and the same issues occured. Is there a posibility that it could be the hall effect switch. I dont think that i have a crankshaft position sensor do i??
